How to create external link with relative path instead of absolute path?
I need to link files outside my vault but I would like to use relative path and not absolute path, this way if I move the folder that contains my vault (folder1 in example) all my links will still work.
To be more clear, this is an example directory:
C:\Users
└─ MyUsername
      └─ Desktop
            └─ Folder1
                  ├─ Obsibian_vault_folder
In my note I want to create an external link and I usually hold ctrl and drag the file but the resulting link is an absolute link as following: [Image.jpeg](file:///C:%5CUsers%5CMyUsername%5CDesktop%5CFolder1%5CImage.jpg)
Since I would like in future to be able to move folder1 without broking the links, I would like to know if there is a way to make the link relative, something like [Image.jpeg](file:///…/Image.jpg)
Thank you :slight_smile:
Did you find a solution?
Obsidian just strips off the leading …/
If you absolutely need to move folders, you can:
  • use symbolic links (better as the files are already outside the vault)
  • do mass search and replace for the absolute path (messy with syncing many files afterwards but not a biggie)
Thank you for the great answer :slight_smile:
