How to clean up old properties, that are not used anymore?
Hi,
I use properties a lot. Since I recently changed my concept how to use them, there some properties, that I don’t use anymore => amount = 0, but still they are listed under “All properties”.
Do you know, how to clean that up?
Thanks in advance,
kind regards,
Silias
Mine clean up on their own unless their was a type mismatch at some point. Clicking Unassign type in the properties view made those go away.
In version 1.5 it will be possible to rename properties globally, so maybe you could delete property or just change name to xxx.
