How to calculate a day difference between two dates (dataviewjs)
Hello,
I am a beginner in Obsidian, the question is simple (I solved more complicated stuff by reading the forum), but I didn’t find a way to solve it.
Thanks in advance!
Calculate a day difference between two dates (dataviewjs)
In dataviewjs block->
const xStartDate= moment(Date.now())
const xEndDate = moment(Date.now()).endOf(‘week’)
//Format is working
dv.span(“Week: " + xStartDate.format(‘dd DD.MM.yyyy’) + " bis " + xEndDate.format(‘dd DD.MM.yyyy’)+”")
//Difference is a large number, which has to be converted into days
dv.paragraph(“-Difference between startOf and endOf week " + (xEndDate - xStartDate))
dv.paragraph(”-Difference between startOf and endOf week " + (new Date(xEndDate) - new Date(xStartDate)))
//I tried with .days, but the result is undefined
dv.paragraph("-Difference in days between startOf and endOf week " + (new Date(xEndDate) - new Date(xStartDate)).days)
Personally, it may be more optimal, but I calculate the difference in days like this :
dv.paragraph("-Difference in days between startOf and endOf week " + Math.floor((xEndDate - xStartDate) / (24 * 60 * 60 * 1000)));
Thanks, I will use your approach too :slight_smile:
Since you’re already using moment.js dates, you could go all the way and use: xEndDate.diff(xStartDate, 'days') to show the day difference between those dates. For more information see thread on StackOverflow.
