How to add AutoSuggest to a settings input
Hi, I’m trying to add AutoSuggest that suggest note files, to an input field in my plugin Settings.
From my research I’ve seen it mentioned that I should use the class AbstractInputSuggest but I can’t find any resources about how to actually call/use this class.
I’d appreciate any insight, or alternative methods for adding AutoSuggest behavior. Thanks!
Searching GitHub to see how existing plugins use it is a good start, I think.
