I have a very useful workflow where I create rather long filenames. The reason is that I use Obsidian academically, and the notes build on each other in very precise ways. I use the filenames as a precise summaries of what the notes themselves state, which creates an extremely useful “interface” to the core ideas of the notes that forces me to carefully consider how they can (or cannot) be used to support an idea that builds on-top of them.
Here is an example of what I mean. In the note itself I make a reference to the source, and I summarize the statement that I find important from the reference. Then I make the filename reflect the statement as carefully as possible. If I don’t, then I will be much less able to detect subtleties in the note that may make it unsuitable for being used in another note. Having the citation in the title also makes it clear that it is a literature note that drastically simplifies further citations in notes that relies on the given note.
START OF NOTE
‘Minimum optimorum’ level of basic need-satisfaction as “the minimum quantity of intermediate need-satisfaction required to produce the optimum level of basic need-satisfaction measured in terms of the physical health and autonomy of individuals” (p.162-163, Doyal and Gough, 1991)
Doyal and Gough define the minimum optimorum level of basic need-satisfaction as “the minimum quantity of intermediate need-satisfaction required to produce the optimum level of basic need-satisfaction measured in terms of the physical health and autonomy of individuals.” (p.162-163, Doyal and Gough, 1991)
Reference
Thus the crucial task in constructing indicators of need-satisfaction is to ascertain the minimum quantity of intermediate need-satisfaction required to produce the optimum level of basic need-satisfaction measured in terms of the physical health and autonomy of individuals. In the spirit of Rawls, we could call this level the minimum optimorum.
Source: pages 162-163 in [[Reference - A Theory of Human Need (Doyal and Gough, 1991)]].
END OF NOTE
I was happy with this workflow, until realized that I cannot copy (and hence backup) hundreds of my note-files since their filenames are too long. Somehow Obsidian is able to create files with too long filenames. The problem then appears when I try to copy those files somewhere else to back them up - doing so doesn’t work.
I see at least two possible “solutions” to the problem.
- Ignore it and continue as is. The files are anyhow on a cloud system and perhaps don’t need further backing up. This means that my work is less secure.
- Manually go through hundreds of notes and make their filenames shorter so that they can be backed up. This sacrifices the clarity and workflow I have created to which I have no obvious replacement.
Neither of these “solutions” seems optimal.
Questions
- Does the forum have any ideas on what I can do? Is anyone else in a similar situation and has found a solution?
- How can one make precise references to the core ideas of notes without relying on the filenames (in the way I’ve described)?
- How can I easily find the notes I’m looking for in the search results without relying on filenames (in the way I’ve described)?
- How (if possible) can I change the filename size limit in Linux (Ubuntu)?
- How can I limit the filename sizes in Obsidian so that files cannot be created with too long filenames?
I hope the query is not too vague. I don’t know how to describe it more accurately. Hopefully it makes sense enough for someone to provide some feedback.
Best regards,
Tobias
