I have been playing with this myself. So far, my solution is as follows. Sequence notes are part of something bigger so I usually have an index note that acts as a loose table of contents. Sometimes, like for an argument that could have multiple premises that are not necessarily connected in an index, then there is no central point even though there is a sequence of thought. Of course, I could create an index once a full argument has been defined, but I don’t know that until I’m done. So, an index allows for moving around. However, it’s really inconvenient if I come upon a note in a sequence and just want to follow it back or forward. For that, I have at the top a link back to the previous note or premise along with a
icon pointing backward and a link at the bottom of the page that points toward the conclusion or next note with a
icon.
It looks like this at the top of the page:
back to [[premise]] or [[index]]
and like this at the bottom of the page:
next [[index]] or [[conclusion]]
It’s a little clunky, but I have noticed when I come upon these notes, it’s fun to follow the trail. For each premise, you just add more backlinks with arrows to the list. If a premise is parallel to others, use up or down arrows to show lateral movement and make a comment such as see parallel premise [[premise]]
It’s a work in progress. Maybe you’ll discover something much better. I think, as long as there is consistency and it’s understood, just about anything will work.
