I’d like to form a filter for a base file that has the form
{A and B} OR {C and B}, for a simple example, look for all .md files in directory A OR in directory B.
I can’t seem to get it right. The only thing I can think of is to set the condition that for all views, look for files with md extension, then for this view set file path A OR B.
The problem is that it requires ALL the views in the base file to be of one extension, so I can’t have different views search for different extensions.
