I’m working on a presentation in Obsidian using Advanced Slides. I am aware that it was discontinued, removed, then re-added to the community plugins database. I may (or may not) try the other slides plugin that was forked from Advanced Slides in the future; however, for now my question is: Is there a way to take a slide thus:
# My Slide Title/Caption
+ List Item 1
+ List Item 2
+ List Item 3
And have Advanced Slides animate the appearance of the individual list items so they appear on screen one after the other after N time? I /can/ click the space bar for each item on the slide, however it’s not really necessary that I pause between items, so it would be less cumbersome to discuss the topics with my audience without having to keep my thumb on the space bar the whole time.
I have tried using the documentation for Advanced Slides and reveal.js to see if I could uncover a way to do this either using fragments, data-auto-animate, and even trying to figure out how to embed javascript into the slide itself to get this working (didn’t spend too long on that, as my JS understanding is basic at best and super rusty.
I understand that this might not be the right place for this type of question, but I didn’t see any kind of support forum mentioned in the Advanced Slides docs or plugin specific help forum here, so if this isn’t the right place let me know what the right place is and I’ll c/p this over there.
Please help me Obi Wans…you’re my only hope!
Thanks
D
