When I have Make.md installed and Spaces enabled, the open link context menu seen with a note file in edit mode when right clicking a link just above a file, which is embedded in the first and stored in the vault, does not open the folder in which the embedded file is stored. (If I open the folder manually, the embedded file is highlighted.) When I disable Make.md or its SPaces option, and use the open link menu, it opens the correct sidebar folder, and the embedded file title text flashes yellow and then stays highlighted.
In a similar way, if I instead of using the “open link” menu item I go to “reveal file in navigation”, then the icon “files” at the top becomes unselected and the selection switches to “spaces”. With Make.md disabled, the sidebar folder containing the original note file is opened and the note file title flashes yellow and then stays highlighted.
Get these two operations to work with Make md installed with Sapces enabled, if possible. (I currently have Spaces disabled.
I have looked on the forum under Make.md posts, but have not seen this described - have I missed something ?
