Hi,
I want to render a greek letter inside a code block but it doesn’t work. I would naively assume that it should look like this:
Something something $\epsilon$
I found no hint on how to do it in the documentation or the forum. Is this supported at all?
holroy
March 29, 2023, 9:10am
2
I think you need to lookup the unicode character for epsilon for use within a code block. Code blocks in general don’t translate other markup beside that connected to its own type.
So using a site like:
Greek Symbols Α Β Γ Δ Ε Ζ Η Θ in UNICODE ✂ Copy & 📋 Paste (◕‿◕) SYMBL you could locate your character and copy-paste it: ε
system
Closed
April 5, 2023, 9:10am
3
