This is a bit of a specific question.
My custom CSS code for the popup window is the following
.popover.hover-popover {
transform:scale(0.9);
width:100vh;
max-height:50vh;
.popover.hover-popover .markdown-embed {
height:50vh;
.markdown-embed-link {
display: none;
I tried including “position” or “z-index” arguments to move the text but it did not work
Now, when i hover over a link, the popup opens as i want. But the note in the popup has a big gap at the top before the headline (see image).
Is there a simple css way to have the text moved up a bit by default or cut the upper part of the note in the popup?
Thank you in advance
