- Open multiple tabs in reading mode. Using Cmd+Shift+[ and Cmd+Shift+] to cycle through tabs should work.
- Switch the active tab to editing mode, and focus in the editor, as if to type something. Attempt to use Cmd+Shift+[ and Cmd+Shift+] to cycle tabs.
Yes. This happens reliably for me even with restricted mode on. I do not have any custom themes or snippets installed.
Even when focused to the editor, Cmd+Shift+[ and Cmd+Shift+] should cycle through open tabs.
The text under my cursor is made to be either left- or right-aligned, and the tab is not switched.
Leaving the tab in editing mode, but clicking the title bar to remove focus from the note body, restores the original tab-switching behavior.
Operating system: ios 26.1 (Apple iPad13,1)
Obsidian version: 1.10.6 (256)
API version: v1.10.6
Catalyst license: none
I’m using a Magic Keyboard, if that’s relevant.
