We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with third-party plugins and custom CSS disabled and see if it’s still reproducible. If it’s an issue with third-party plugins or themes, try contacting the author for help. Once you’ve done the above, delete this line.
I had created a hot key for following link under the cursor. However, when I have "search" window activated. This hot key does not work. I have to close the "search" window for the note.Expected result
hot key to work in all the situation inside the noteActual result
The hot key does not work when I have the “search” bar activated
- Operating system: Windows
- Debug info: Close the “search” bar
