This is a short guide for anyone who’s also using Obsidian for Hookmark notes (i.e. ⌃+H
and ⌘+N
Problem: The default logic of Hookmark does not create a hook-link between the document and the Obsidian note, so I’ve spent some time debugging the “New Item” script.
As a result, the new Obsidian note had a Markdown link pointing to the document, but the document had no indication or link to the obsidian note.
For me, the following setup solved the issue
- I’ve configured Hookmark to use the “hook://file” schema. It might work with other options, but I did not test it.
- Use a modified version of the “New Item” script.
The key element is the very last line, which originally was return "hook://link-to-new"
- apparently this does not work. Using the Obsidian URL schema solved the problem: return "obsidian://hook-get-address"
→ If you also have any other Hook & Obsidian workflow tips or improvements, please share them with us
