We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with third-party plugins and custom CSS disabled and see if it’s still reproducible. If it’s an issue with third-party plugins or themes, try contacting the author for help. Once you’ve done the above, delete this line.
Create a table with several columns
Add a link with a very long URL. Notice in code edit mode the link does not wrap like it does in a paragraph
Press end to get to the end of the line of text. The editor scrolls to the right as expected
Press Home to get the beginning of the text. The cursor moves to the farthest left that it can but the editor does not scroll to the left so you are stuck in the middle of the line. Pressing home again does not scroll the editor window
Long links in table colums should wrap as they do in the editor
The editor should scroll to the left when the home key is pressed and the line is very long
Long links in table cells do not wrap in edit mode
Long lines that are not wrapped cause editor to not scroll left when at end and the Home key is pressed
Operating system: Windows 11 (I know I’m ashamed of it too)
Debug info:
Obsidian version: v1.0.3
Installer version: v0.15.9
Operating system: Windows 10 Pro 10.0.22621
Legacy editor: off
Create a wide table that goes beyond the width of current tab/column
Set the cursor in the string, press End once: the cursor with jump to the visible end of the text
Press End twice: the cursor will jump one column width further, until the true end of the live is reached
Now try to press Home: the cursor will jump to the start of visible text, but pressing Home again won’t make the view to scroll to it. Sometimes the cursor won’t even go visibly go there as well.
