Holding/long-pressing on a bases column on mobile does not do anything
  1. Make new vault on mobile
  2. Create new base
  3. Try to hold/long-press on a column
  4. Nothing happens.
Yes
Being able to resize and reorder the columns.
Nothing happens when attempting to drag the columns, the drag handles to resize the column sometimes get stuck being visible and don’t do anything.
Operating system: android 14 (samsung SM-A155F)
Webview version: 140.0.7339.155
Obsidian version: 1.9.12 (237)
API version: v1.9.12
Live preview: off
https://i.imgur.com/KGik6A5.mp4
It worked fine a couple days before this happened. Happens in a new vault and my old vault with plugins, snippets, theme disabled. Someone else confirmed they have also experienced this in the #obsidian-bases channel on the Discord.
Tap Hold and move works for me for reordering
Resize is obtained by “Tap Hold and move” on the column divider.
