I am trying to import annotations from Zotero, display the annotations in callouts, and have the annotations available to transclude in other links.
- Import annotations directly into callouts and assign block IDs. Result: I get the callout I want; I get no duplicated content that I want; but the transcluded note includes the callout formatting that I don’t want.
- Import annotations, assign block IDs to the annotations, and in the same note transclude the annotation into a callout. Result: I get the callout I want; I get the ability to transclude the block into other notes I want; but the content of the block is displayed twice (with one of them undesirably formatted).
- Import annotations, assign block IDs, and transclude into callouts as in the last bullet, but attempt to hide the source blocks within comments. Result: The transcluded annotation cannot be found.
I believe I could implement a template with Templater that could build a second file during import to contain the block annotations separately from the main note, but that’s two files that need to be coordinated when reimporting annotations, which seems brittle to me.
Short example:
test.md:
[!info]
![[test#^1234]]
%% mechanism to hide this block without suppressing this block %%
info block content
^1234
%% end hide block mechanism %%
