Help with Tracker Plugin when my frontmatter is nested
I’m trying to use the Tracker Plugin to parse my daily frontmatter tags to create a chart.
My frontmatter looks something like this:
  • Habits:
    • Habit_1:
    • Habit_2:
    • etc
Now, i want to create a tracker chart only for Habit 2.
I tried as SearchTarget:
  1. Habit_2
  2. Habits/Habit_2
  3. Habits\Habit_2
None will work, but, the message i’m receiving is “No valid Y value found in notes.”
Or course, if I move Habit_2 outside of the structure, everything is ok…
Thanks in advance for any help you can provide.
I have never used the Tracker plugin before, but maybe you try
searchTarget: Habits.Habit_2
Thanks @mr_abomination!
  • i already tried - and is not working. Got the same error as above.
Still looking for a solution.
Have you looked on the GitHub for the project, or even opened an issue there?
Yes, i posted a Feature Request.
