I am using obsidian for notes for school and I use span fields to highlight certain types of notes with different descriptions, using CSS to color the span fields as well. (for instance, when I note something in a text I am reading that I disagree with I put Disagreement and then I use CSS to have the text in the span, “Disagreement,” appear in Yellow). I was trying to set up a text extender (Espanso) to create a shortcut so I didn’t have to copy the span strings every time, but I noticed that when the text is entered from the expander, the live preview and reader view do not show the text with the CSS colored highlight
i suggest u use <mark>
tag instead, it would be more direct. anyway, no doubt u can do that manually using <span>
or <mark>
, but i guess you should give this plugin a try first? they are available via obsidian’s community plugin
obsidian://show-plugin?id=highlightr-plugin
for custom highlights (i think should be exactly what u want)
obsidian://show-plugin?id=obsidian-text-expander
obsidian://show-plugin?id=text-snippets-obsidian
text expander plugins for obsidian (in case u want a text expander that works only within obsidian)
Thanks. that really helps!
