  • Searching the forum and help wiki
  • Playing around with the forces in graph settings
Kia ora,
I’m trying to make my graph settings a bit more static. Sometime the links and nodes overlap, making it look like there’s a connection when there isn’t. Though I can manually fix this, it’s annoying that the layout refreshes every time I return to graph view, meaning I have to fix it ever time. It seems like it’s not possible to pin nodes in a certain place, but is there a way to have links set to not overlap each other?
Also, could someone explain the difference between link force and link distance? They both seem to do the same thing and change the distance between nodes.
