Trying to use a community plugin and I’m such a newb I can’t make it work. Is this the place to ask about it, or should I go directly to creator?
Here, unless there is an internal issue with it.
I’m trying to use the plugin, “Folder by tags distributor”.
I don’t understand how to actually trigger the move from the options offered.
The creator’s Github discussion forum isn’t very active.
Hi, I renamed your topic so people know what you’re asking for help with.
I haven’t tried the plugin, but I see the documentation.
First of all, since this plugin moves content around, I highly recommend you make a safe backup copy of your vault! Just in case.
Redistribute all notes to folder by tags
command.” you can do that in one of two ways:
If none of that helps, can you try to describe where you are stuck?
I think I got it figured out. Thanks much.
