Help with embedding images in a Dataview Table
Hi, I was wondering if someone knows how to properly embed the images.
This is the code:
```dataview
TABLE WITHOUT ID
nonnull(rows.file.link)[0] as Project,
rows.OpenTasks.text as "Open Tasks",
nonnull(rows.Urgency)[0] as Urgency,
nonnull(rows.DueDate)[0] as Date,
nonnull(rows.Responsible)[0] + "<br>" + nonnull(rows.Department)[0] as "Responsibel and Department",
embed(link(meta(CoverImg).path, "125")) as ""
FROM "Projects"
WHERE file != this.file
WHERE Completed = False and Limbo = False
FLATTEN file.inlinks.file.tasks as AllProjectTasks
FLATTEN filter(AllProjectTasks, (task) => !task.completed) as OpenTasks
group by file.link
I have tried many different combinations of rows. but none of them work. The image I want to embed is linked to in the property named “CoverImg”.
If I don’t add any rows. the error is:
  • No implementation of ‘meta’ found for arguments: null
If I add rows. (like this: embed(link(rows.meta(CoverImg).path, "125")) as "" the error is:
  • Cannot call type ‘array’ as a function
I believe the embedding should be possible because it works when I don’t use group by. There is some combination of rows. and maybe nonnull that I’m not aware of.
If anyone knows how to do that it would be greatly appreciated. Thanks :slight_smile:
