Help with dataviewjs query
if
dv.list(
	dv.pages('"TCPA/Cases"')
		.where(p =>
			p.payment_due
		.payment_due
yelds
* 24457.85
* 1612.8
* 3000
* 3600
why does
dv.func.sum(
		.where(p =>
			p.payment_due
		.payment_due
return nothing
Most likely because you’re trying to sum texts…
The following is untested, but try something along the lines of:
```dataviewjs
dv.func.sum(
		.where(p =>
			p.payment_due
		.map(p => parseFloat(payment_due))
no luck.
It seems I was a little tired when answering yesterday. A dataviewjs needs to have some sort of output function to present any result. In the first case you’re using dv.list(), but in the second one you don’t have anything, so the sum is actually calculated OK, but it’s never displayed.
```dataviewjs
const sum = dv.func.sum(
  dv.pages('"ForumStuff/f77/f77973"')
    .where( p => p.payment_due )
    .payment_due
dv.paragraph("Due payments: " + sum.toFixed(2))
This variant calculates the sum, and uses dv.paragraph to present a full block with the result. You could also use dv.span() for inline variants. I’ve also added a little bit of formatting just for the fun of it, and then we end up with:
