Help w/ Tracker Plugin and tasks with wikilinks
I want to Track tasks in my daily notes that have wiki links inside them, but the Tracker Plugin doesn’t appear to be able to do this.
The task I want to track looks like this
  • [[MorningRoutine]]
MorningRoutine is a file that contains a list that I must follow to check it, so it makes sense to have it linked in the task itself.
I have tried giving the task content simply as it appears in the file has follows:
searchType: task.done
searchTarget: [[MorningRoutine]]
month:
But I get the ‘No valid date as X value found in notes’ that doesn’t make sense because my daily notes have a heading in the correct format and when you change the task to another one that doesn’t have a wikilink, it tracks it with no problem.
I have also tried:
searchTarget: '[[MorningRoutine]]'
month:
I get the ‘No valid Y value found in notes’
and finally I tried
searchType: text
searchTarget: '- [x] [[MorningRoutine]]'
month:
But got the same last error.
For now, I think my only option is to not have the notes linked inside my tasks…
Also, I have other tasks with links (the [link](actual link) format) and they also don’t seam to work :confused:
Just a long shot, but does it work with just “MorningRoutine”?
It should right?! That was my previous setup before I added the wikilink. Sadly it doesn’t work :slightly_frowning_face:
Couldn’t get it to work, even by adding plain text to the task field. I managed to find a hack to make the task parsable by obsidian-tracker, obsidian-tasks and contain a wikilink by hiding the link between two task emoji metadata markers:
- [ ] Practice Drawing 🔽 ([[goals#Drawing|x]]) 🔽
Tracker will successful match this task for searchTarget: "Practice Drawing"
Adding another marker at the end is required for obisidan-tasks to properly parse the task too, but you don’t need it just to get obsidian-tracker to work. I recommend using the priority markers since adding dates you don’t want is more likely to mess up task retrieval, although I also considered using a “scheduled date” instead.
