Help: Unwanted spaced out chars in the context menu of the Spaces side panel
Something changed the way the context menu in the side panel looks in my installation. I’ve tried uninstalling plugins and the custom theme, but it doesn’t seem to want to change back.
Does anyone know a way to manually edit this aspect of the current theme so I can make it look normal again?
A few things to check:
  • Do you have any CSS snippets enabled?
  • Is that happening only in that context menu or all of them across the app?
  • Spaces comes from the MAKE.md plugin, so you could try disabling that and restating Obsidian (make sure to restart to fully unload it).
