Click “Settings”, searched through all settings “tabs” for “3rd Party Plugins” or “Community Plugins”.
I want to add 3rd party plugins.
The help page says that there is Community Plugins tab in settings. https://help.obsidian.md/Advanced+topics/Community+plugins
But I see no such option in my Obsidian 0.9.4 on Windows. Screenshot attached.
How do I enable this?
Install the latest version, why are you using 0.9.4 ?
Edit: go to “about” → “check for updates” or download from the official site directly
Thanks.
I thought that I had installed the latest version. But I was somehow launching an old installation. Removing the old version and reinstalling the new version solved the problem.
