I have been trying to modify the template to import the annotations from zotero into my obsidian.
Although ive seen many templates in the web, i cannot modify it to do what I want.
I want a Header for each different color I used for highlighting information in the artice.
i.e {%- macro colorValueToName(color) -%}
{%- switch color -%}
{%- case “#ffff00” -%}
General / Introduction
{%- case “#ff7f7f” -%}
Needs
{%- case “#ffbf7f” -%}
Gaps or limitations
{%- case “#7fff7f” -%}
Methodology related
{%- case “#7fffff” -%}
Important results
{%- case “#ff7fff” -%}
Concepts or Definitions
{%- case “#bf7fbf” -%}
Definitions / concepts
Study Area
{%- endswitch -%}
{%- endmacro -%}
And all i want is to import all the sentences i highlighted with yellow to be under the header “General”, all the ones with orange under the header "Needs"and so on and so on.
This is the code I have so far:
Needs
Gaps or limitations
Methodology related
Important results
Study Area
{%- endswitch -%}
{%- endmacro -%}
{% persist “annotations” %}
{% set annots = annotations | filterby(“date”, “dateafter”, lastImportDate) -%}
{% if annots.length > 0 %}
{% for color, annots in annots | groupby(“color”) -%}
{{colorValueToName(color)}}
{% for annot in annots -%}
[!{% if annot.color %}|{{annot.color}}{% endif %}]
{%- if annot.annotatedText %}
{{annot.annotatedText | nl2br}}
{%- endif -%}
{%- if annot.imageRelativePath %}
![[{{annot.imageRelativePath}}]]
{%- endif %}
{%- if annot.ocrText %}
{{annot.ocrText}}
{%- endif %}
{%- if annot.comment %}{{annot.comment | nl2br}}
{%- endif %}
{% endfor -%}
{% endfor -%}
{% endif %}
{% endpersist %}
but I still dont know how to change it to do what i want. This is a screenshot of what i see:
Please, if anyone can help me, im not the best with coding, so eveything is taking longer than expected.
Thank you!!
