I’m trying to nest headers in files so they are foldable in edit mode.
I’ve created a header tag (3 '#'s) that’s working fine. But when I try to nest another one below it a few lines later, it works fine in preview mode, but doesn’t automatically move out at the proper nest level in edit mode:
Am I doing something wrong that’s keeping it from moving to the appropriate level?
Can you paste the raw text here in triple-backtick code fencing? These: ```.
Maybe what’s avoiding the proper nesting is a rendering problem caused by the GRANT <permissions>… line.
<permissions> and other strings between <> in that line are interpreted as HTML tags.
You should enclose the whole line in backticks (inline code) or get it inside a code block.
