Having a problem with line breaks and >-
the small pieces of solid matter in a liquid that have fallen to the bottom
  • plural grounds
there will always be a line break between the first line and the second, i dont want that, i want 2 continuous line! How to do it?
I don’t see that in the default theme. I’d guess your theme is adding some margin. If the theme supports the Style Settings plugin it might have a setting in there. If not you’ll need to use a CSS snippet.
