Currently it is very helpful to use the “Jump to group” command within canvas, but it can be a slower process and difficult to remember group names when you have many. Often times I have canvases set up in such a way that I will often want to quickly navigate from a specific node in the canvas to just one or sometimes a few different groups.
Allow for the ability to create links to groups. I would be okay with however this might be accomplished. I imagine there may already be some existing syntax in other software for similar functionality that might be a logical choice, but I am unaware of them.
I can add an adjacent card reminding me of the group name/names that are relevant to allow for easier navigation. Possibly, I could set up a macro to copy the selected group name from one of these cards, run the Jump to group command, paste the group name, then press enter. However, I haven’t tried this yet.
Another option is to create canvas connection lines, and use the “Go to target/source” commands. The downside is that these lines will make the canvas a lot more busy and chaotic. This is especially true since the use case is mainly in situations where the destination group is quite far away.
Here is a relevant request that specifically asks for this same functionality but from within notes. Technically, I guess if that request were implemented, in the canvas you could embed notes with the group links, and utilize them. Canvas: Link to a group / a selected section / a card from Canvas inside a note
Thanks!
