Group BY - Need Assistance Please
I have this dataview code:
TABLE WITHOUT ID l.text AS “Last Entry”, file.link AS “Client”, row[“modified date”] AS Modified
FROM “Active Matters”
FLATTEN file.lists AS l
SORT Client DESC
Which gives me last entry, client, and date
I want to group by the client name so it looks like:
Entry Client Date
Entry
Entry
Entry Client Date
Entry
Can someone advise how to do that, please?
I really wanted to grab the last text block but that looks like it involves dataviewJS…
(see image)
Do you mean like this:
TABLE WITHOUT ID rows.t AS "Last Entry", Client, rows["modified date"][0] AS Modified
FROM "Active Matters"
FLATTEN file.lists.text AS t
GROUP BY file.link AS Client
SORT Client DESC
DQL (the Dataview Query Language you’re using, as opposed to DataviewJS) can return the part you circled if you use headings (of any level).
For example, when you format the notes like this:
## 2026-01-16
- David
## 2026-01-15
- Received
… this Dataview query:
TABLE WITHOUT ID map(rows.t.link, (l) => meta(l).subpath) AS "Heading", rows.t.text AS "Last Entry", Client, rows["modified date"][0] AS Modified
FLATTEN file.lists AS t
SORT Client DESC
… returns this:
You can group that in other ways; I wasn’t sure how you would want it.
And/or you could adjust the layout:
TABLE WITHOUT ID map(rows, (r) => r.h + " • " + r.t.text) AS "Last Entry", Client, rows["modified date"][0] AS Modified
FLATTEN meta(t.link).subpath AS h
SORT Client DESC
Thank you for replying. I am going to apply your suggestions and see if I can get to work correctly. Have a great day!
Hello, this is working great. I just have one question: Is there any way to limit the number of entries in the results? Some of these will have numerous entries. I have provided a couple of images to help visualize what I’m asking. If you have any ideas, please let me know. Thanks in advance.
The dataview code is here:
TABLE WITHOUT ID map(rows.t.link, (l) => meta(l).subpath) AS “Last Entry”, rows.t.text AS “Entry Details”, Client, rows[“modified date”][0] AS “Record Modified”, “#uniqueTableId” AS “”
SORT map(rows.t.link, (l) => meta(l).subpath)[0] DESC, Client ASC
