I sometimes like to have the main graph open to one side of my workspace and the local graph open in a small sidebar window. Often a graph will fail to load, or disappear while I’m working. When this happens a console error is generated:
out:blank:1
[.WebGL-0000534803294E00]GL Driver
Message (OpenGL, Performance, GL_CLOSE_PATH_NV, High):
GPU stall due to ReadPixels
(this message will no longer repeat)
Didn’t find anything relevant in the forum. Usually quitting the window, opening another and reloading the graph works.
Specs
Windows 11 Professional (x64) Version 22H2
Memory: 16Gb
Processor: 3.70 gigahertz Intel Core i7-8700K
Board: ASRock Z390 Phantom Gaming-ITX/ac
Video support: “Intel® UHD Graphics Built-in Visuals : Intel® Quick Sync Video with AVC, MVC (S3D) and MPEG-2 Full HW Encode1, Intel® InTru™ 3D, Intel® Clear Video HD Technology, Intel® Insider™, Intel® UHD Graphics, DirectX 12”
Summary
I’m not a gamer and not very knowledgeable about GPU specs and issues, but this Phantom Gaming-ITX mobo is supposed to have decent onboard graphics processing.
I did find an interesting reference to “ReadPixels” on StackOverflow, where a commenter offered:
readPixels is fundamentally a blocking, pipeline-stalling operation, and it is always going to kill your performance wherever it happens, because it’s sending a request for data to the GPU and then waiting for it to respond, which normal draw calls don’t have to do.
Do readPixels as few times as you can (use a single combined buffer to read from). Do it as late as you can. Everything else hardly matters.
Can anyone here suggest whether I have a personal hardware limitation, or if this is an unusual coding issue that should maybe be addressed as a bug?
