GraphFrontier - graph plugin with layout saving, pinning, and multi-node dragging
Hi everyone,
I’d like to share GraphFrontier, an Obsidian plugin for working with note graphs in a more deliberate and structured way.
GraphFrontier is not an extension of the core Graph View. It is a separate plugin with its own rendering and physics engine, built for workflows that are hard or impossible to achieve in the default graph.
The main features I wanted to focus on are:
  • saved layouts - keep node positions exactly where you want them between sessions
  • pinning - place nodes manually and build stable graph structures
  • mass dragging - move linked or selected groups of nodes together instead of rearranging everything one by one
The goal is to keep the strengths of graph-based exploration while making large graphs more controllable, more readable, and more practical for real work.
moving
save
What it can do
Some of the main features:
  • Save node positions and reopen the graph with the same layout
  • Pin nodes exactly where you want them
  • Pin nodes to a grid
  • Move linked nodes while preserving structure
  • Place linked nodes on orbits around a selected node
  • Apply stronger attraction to specific nodes
  • Paint links for better visual clarity
  • Hide edges you do not need
  • Explore context with Find and Filter modes
  • Separate orphan files from primary nodes
  • Show linked attachments on node orbits
  • Use commands and hotkeys for faster workflows
  • Copy linked node names and paths directly from the graph
I’ve found it especially useful for:
  • large note collections
  • documentation
  • visualizing relationships in structured knowledge
  • exploring connected ideas without losing layout control
Installation
GraphFrontier is not in the Community Plugins browser yet.
Install with BRAT
You can install it with BRAT using this repository URL:
https://github.com/pikiby/GraphFrontier
Manual installation
You can also install it from GitHub Releases:
https://github.com/pikiby/GraphFrontier/releases
Steps:
  1. Download the zip
  2. Extract it to <your-vault>/.obsidian/plugins/graphfrontier/
  3. Enable GraphFrontier in Settings -> Community plugins
If you try it, I’d really appreciate feedback on usability, performance, and graph workflows that you feel are still missing.
Thanks!
Hi
This plugin shows promise! I am working with GraphFrontier in the MacOS environment. Am struggling resolve the following error message when I try to export: “Failed to write static HTML report” error. I have given Obsidian permission to write to my hard drive so that does not seem to be the problem.
Resolved. I am not a programmer so it took some time. Resolution involve changes to javascript in the main.js file.
