Graph view zoom out and disappear (glitch)
The graph will apears for a few seconds after opening graph view, and then dissapear. I tried to zoom in / out, move around, reset setting in graph view, delete graph config in .config. I tried to create new vault and there all is ok. So it relate to vault somehow.
  • open vault
Did you follow the troubleshooting guide? Yes
Expected result: To see the graph
Actual result: See attachments
Obsidian version: v1.7.7
Installer version: v1.7.6
Operating system: Darwin Kernel Version 24.1.0: Thu Oct 10 21:03:15 PDT 2024; root:xnu-11215.41.3~2/RELEASE_ARM64_T6000 24.1.0
Live preview: off
If it works fine in another vault, then it’s something about your main vault and you need to follow all of the troubleshooting guide.
  • I disabled the plugging
  • disabled the css
  • disabled the set default theme
