I added quotes " " around the words after I select the path and that helped but did not eliminate the problem. For example, right now I have the path set for Path:“Evergreen Notes” and I get all 16 of those but I also get 2 that are Literature notes and stored in the literature note directory.
In addition, I have colors set up. Green is for evergreen notes and all of them are green except the two literature notes (which is correct for the coloring) and then one evergreen note is red which is associated with my work directory (and this is not correct as it should be green). It is an evergreen note about my work, but it is stored in the evergreen folder so I’d expect this to be green and not red. I’d appreciate any help. Thank you!
Other than adding quotes, I’m not sure what to do. I’ve double and triple checked that they are in fact in the correct directory and they are, so I’m not sure what to do now.
