  1. Click “Open graph view”
  2. Drag the Graph view panel into the Side Panel (which also contains Outline, Tag pane and Backlinks).
  3. Try to open a note from within the Graph View
Hover over note in Graph view should highlight the note / allow to click on the note to open it (this works fine when Graph view is a separate panel outside of the Side panel).
Hovering over note has no effect, except for very specific locations (e.g., top left, slightly over note; location varies however, making it nearly impossible to open a note).
  • Operating system: MacOs BigSur
  • Obsidian version: v0.12.19
Issue occurs only when Graph view is inside the Side pane (that also contains outline/tag pane/backlinks).
Why it matters: Having the Graph view in the side pane allows me to quickly jump to different notes while keeping my Graph view open.
Please post a screen recording of this happening in the help vault.
Thank you for the quick reply @WhiteNoise! Do you mean like this? obsidian://open?vault=Obsidian%20Help&file=graph%20view%20in%20side%20pane
No, I mean use a screen recording program to record you having this problem on the help vault. I can’t reproduce your problem.
Animation4
Ah that makes more sense. Turns out the issue seems to be the theme “Traffic Lights”, and I see there is already an issue on github: Graph node are misaligned · Issue #6 · elliotboyd/obsidian-traffic-lights · GitHub. graph_view_traffic_lights
I’ll mark this topic as solved and add a link to gitlab, thanks for your help on how to debug!
