I have the graph analysis plugin installed and activated. I have the NLP plug installed and activated. When I select an algorithm in the plugin settings and run graph analysis for that algorithm the results do not display in the right sidebar.
It appears using the plugin with the minimalist theme has been a problem for some. Hope that’s not the explanation of my problem.
I have watched the video on the basics of using this plugin. There is nothing on it on the help site. I also found nothing on it here.
