tosho
September 26, 2024, 7:56am
1
I want to use a hotkey (Command+Shift+[) to kick “Go to previous tab”, but nothing happens.
Assign another hotkey to “Go to previous tab” and found it works
Try to assign “Command + [” to another hotkey, but the key cannot be assigned (nothing happens when I try to assign the hotkey)
“Go to next tab” (Command+Shift+]) works
Command+Shift+[ works in Chrome (go to previous tab)
I tried to find conflicting hotkeys at the system or application levels but could not find them.
I’d suggest try it in the Sandbox vault, or a new test vault. If it works there, you may have narrowed it down to settings in your vault.
Although since you said you are having trouble even assigning the hotkey, I imagine it is at the application level.
vxcall
October 11, 2024, 3:02pm
3
I have completely same problem with my both 2 different Macbooks too.
I tested couple of apps but others don’t have this issue, just Obsidian ignores whatever hotkey that includes Command+[
reproduced OS version↓
Sonoma 14.1.1
Sonoma 14.5
Sequoia 15.0.1
vxcall
October 12, 2024, 4:29am
4
I fixed it. it’s OS bug where it misunderstand keyboard layout. OS thinks US keyboard a Japanese keyboard.
fixed by following instructions in this article
https://aotamasaki.hatenablog.com/entry/command_with_open_bracket_is_unavailable
system
Closed
November 9, 2024, 4:30am
5
