Global graph view does not show from keyboard shortcut or from command pane. Graph button in toolbar shows graph fine. Local graph works fine.
¯_(ツ)_/¯
This is in multiple vaults, with all custom css, themes, and community plugins turned off.
Graph plugin is enabled.
Reboot.
Start obsidian.
Hitting ⌘G, or ⌘P then selecting “Open Graph View”, does nothing. Local graph works fine. Those keys are bound.
Graph pane appears and renders
Nothing happens.
  • Operating system:
    Mac OS Big Sur 11.4 20F71
  • Obsidian version:
    v0.12.11
I’m facing the same issue after upgrading to the newest version v0.12.11
will be fixed 0.12.12
