Whenever I type an incorrect word, it will be underlined showing that it’s not found in the dictionary. If I put the cursor on the word, and press Fn + Ctrl, I don’t get the expected result.
The expected result would be to open the pop-up where I can then select the correct word with the arrow keys (the same as if I were right-clicking on the word with the mouse). This is standard behaviour in most programs at least on Windows.
What happens is that pressing Fn + Ctrl right clicks on the position of the mouse, rather than on the position of the cursor.
  • Obsidian version: 0.10.10
We don’t support this. If there isn’t a feature request about this, open a new one.
I didn’t even know that Fn+Ctrl was shortcut for this in win
