Disclaimer
- Is this project open source? Yes — MIT-licensed.
- Is this project completely free? Yes — the blueprint and vault templates shared here are free to download and use. No paid service is required to use this Markdown workflow.
- Is this project made with AI beyond the author’s ability to comprehend how it works? No. AI assisted the work, and I understand and can explain the template structure and deployment tool.
Hi, I’m Owen, a contributor to FridayOS. I’d like to share a Markdown vault structure for people whose notes mix source material, ongoing projects and reusable knowledge.
The Six-Brain Method uses six folders with different responsibilities:
| Folder | Purpose |
| inbox | Capture material before choosing where it belongs |
| exec | Track goals, progress and next actions |
| wiki | Develop reusable understanding with source links |
| skills | Keep repeatable methods after review |
| raw | Preserve original evidence |
| system | Record operating rules and authority boundaries |
A small workflow example
Suppose you are preparing a brief from three source documents:
- Keep the original documents in
raw/. - Record the question, expected outcome and next action in
exec/. - Link relevant existing notes from
wiki/, keeping references to the sources. - Write the brief in
output/and review its claims against the originals. - Put reusable insights back into
wiki/. If the procedure proves useful repeatedly, document it inskills/.
Not every note needs to pass through every folder. The purpose is to distinguish evidence, current work and reusable understanding while keeping them connected.
Using it with Obsidian
- Download the blueprint package and follow its guide to preview, create and check a new empty target folder.
- In Obsidian, choose Open folder as vault and select the generated knowledge folder.
- Read
START-HERE.md, then try one small task with documents you are allowed to use. The notes are ordinary Markdown and can be read and edited without an AI connection.
The package includes blank templates and starter rules. It also supports project sub-brains and separate deliverable, work and archive areas. A separate Chinese fictional-company sample vault and bilingual guides are included in the repository for exploration.
FridayOS 1.0 repository · Deployment guide and download
The deployment tool needs Python 3.9+ and runs offline after download. Current deployment acceptance is on Windows. Existing-vault migration and automatic backups are not provided. The folders do not enforce permissions or automatically connect a model; this post is about the free vault structure and manual workflow.
“Six-Brain” is a design analogy, not a claim about biological brain mechanisms. I’m interested in feedback on the folder responsibilities and the first-use instructions: which distinction feels useful, and which adds unnecessary effort?
