Currently the only way to register plugin is to define
main.ts
(or main.js
with
export default class MyPlugin extends Plugin { ... }
From what I see in implementation of loadPlugin()
in in app.js
, that’s the only way Obsidian plugin system can discover the plugin.
However, using export default
is considered a bad practice in the modern ts/js.
It would be great if Obsidian provides a way to avoid the export default
approach to enforce modern best practices.
export { MyPlugin as SomeMagicNameThatObsidianRecognizes };
