Format property block via css
Hello, I want to access the metadata-properties-heading element via css, specifically I want the property block to display “collapsed” when opening the note (default is expanded).
I guess accessing the element is like this:
```css
.metadata-properties-heading {
But how to specify that the element should be displayed collapsed is not clear to me.
Maybe someone can help me.
I’ve just discovered that
.metadata-container .metadata-content{
  display: none;
.metadata-container:focus .metadata-content{
  display: block;
works almost perfectly, exept for the fact that you can expand only via the folding arrow indicator
i dont know if the “focus” part is needed/even works, but if anyone knows-correct me if im wrong
