Obsidian allows you to place ! front of links for embedding internal note or other media files.
When trying to “Follow Link Under Cursor” instead of opening the note in the current pane, it opens another one to the right:
Open any embedded link with “Follow Link Under Cursor”
Did you follow the troubleshooting guide ? [Y/N]
yes
the embedded note should open in the current pane and the history should be updated with the new note
a new tab is opened at the end of existing tabs and history is reset
Obsidian version: v1.4.16
Installer version: v1.4.16
Operating system: Darwin macos 22.6.0 Darwin Kernel Version 22.6.0: Fri Sep 15 13:41:28 PDT 2023; root:xnu-8796.141.3.700.8~1/RELEASE_ARM64_T6000 arm64
Catalyst license: supporter
Insider build toggle: no
Live preview: no
Legacy editor: off
