Footnotes index / numbering is incorrect
  1. open sandbox vault in Obsidian 1.14.4 + Installer 1.14.4
  2. paste the content below (from Proxmox VE Storage)
  3. observe the bug
MD Content to repro bug
### Comparison
| Description    | Plugin type | Level    | Shared  | Snapshots | Stable |
| ZFS (local)    | zfspool     | both[^1] | no      | yes       | yes    |
| Directory      | dir         | file     | no      | yes [^2]  | yes    |
| BTRFS          | btrfs       | file     | no      | yes       | TP[^5] |
| NFS            | nfs         | file     | yes     | yes [^2]  | yes    |
| CIFS           | cifs        | file     | yes     | yes [^2]  | yes    |
| Proxmox Backup | pbs         | both     | yes     | n/a       | yes    |
| CephFS         | cephfs      | file     | yes     | yes       | yes    |
| LVM            | lvm         | block    | no[^3]  | yes [^4]  | yes    |
| LVM-thin       | lvmthin     | block    | no      | yes       | yes    |
| iSCSI/kernel   | iscsi       | block    | yes[^3] | yes [^4]  | yes    |
| iSCSI/libiscsi | iscsidirect | block    | yes[^3] | yes [^4]  | yes    |
| FC/SAS         | native[^6]  | block    | yes[^3] | yes [^4]  | yes    |
| Ceph/RBD       | rbd         | block    | yes     | yes       | yes    |
| ZFS over iSCSI | zfs         | block    | yes     | yes       | yes    |
[^1]: Disk images for VMs are stored in ZFS volume (zvol) datasets, which provide block device functionality.
[^2]: On file based storages, snapshots are possible with the *qcow2* format, either using the internal snapshot function, or snapshots as volume chains. Creating and deleting internal *qcow2* snapshots will block a running VM and is not an efficient operation. The performance is particularly bad with network storages like NFS. On some setups and for large disks (multiple hundred GiB or TiB sized), these operations may take several minutes, or in extreme cases, even hours. If your setup is affected, create and remove snapshots while the VM is shut down, expecting a long task duration.
[^3]: With iSCSI, FibreChannel (FC), or SAS block storage as shared storage in a cluster, LVM is used to split the LUN into virtual disks. The [Multipath Guide](https://pve.proxmox.com/wiki/Multipath) explains how to configure it in a cluster, including multipathing which is usually a requirement in these scenarios.
[^4]: Since Proxmox VE 9, snapshots as a volume chain have been available for VMs. These snapshots use separate volumes for the snapshot data and layer them. For more details, see the description for snapshot-as-volume-chain in the [LVM configuration](https://pve.proxmox.com/pve-docs/chapter-pvesm.html#pvesm_lvm_config) section.
[^5]: Technology preview with best-effort support.
[^6]: Fibre Channel (FC) and SAS block storage is handled directly by the host without a dedicated storage plugin.
Did you read and follow the Troubleshooting Guide ? [Yes]
Footnote numbering/links correspond to the correct footnote
Footnote [^5] e.g. links to ^3, ^3 points incorrectly at ^4, and ^4 points at ^5…
see screenshots
	Obsidian version: 1.14.4
	Installer version: 1.14.4
	Operating system: Darwin Kernel Version 27.0.0: Tue Aug 11 21:05:48 PDT 2026; root:xnu-13432.1.9~1/RELEASE_ARM64_T6041 27.0.0
	Catalyst license: supporter
	Insider build toggle: on
	Plugins installed: 0
	Plugins enabled: 0
It doesn’t look wrong to me.
everything is relabeled/reorder. Both the source and destrination.
But things point still to the right place.
@WhiteNoise thanks for looking but confused by your reply. First, no it is not correct. Not only visually, but the actual footnote link, when clicked, leads to the wrong footnote. I didn’t mention that in the OP (didn’t think it was necessary).
MEANING: if you click on the BTRFS footnote at the far right of row 3, it should take you to footnote 5, but instead you land on 3. How is that correct??
From your source file
You are confused by the numbers. But those are labels.
Wow, ok it seems you’re right. Had to look at it a few times just to see what was going on. Now THAT is confusing for sure. Guess I never understood how the footnote numbering worked- or was it changed at some point?
Hi, heavy footnotes user here.
Those characters aren’t “numbers” in the sense of an ordered list. The footnote identifier is a text string, regardless of whether you’ve typed a digit or an alphabet character or a dash. The ordered numbering happens at rendering time.
Think of them as labels rather than numbers.
To that end, I rarely use numbers. Descriptive labels like [^stable-TP], [^snap-yes], [^snap-no] keep the matchups clear. But if that’s too much work, than even random strings of two to six alphanumeric characters can help avoid confusion.
Ok, thanks everyone. TIL
