Folder Note Plugin: Add description note to folder
Hi,
Is anyone else having an issue with AidenLx’s Folder Note? I am unable to click the folder notes in the file tree, I can only browse the file tree the old fashioned way. This is happening on both OSX and mobile, with the Minimal theme. I’m on the latest version of Obsidian and all the plugins are updated.
Hi @exaltcovert,
this problem is known, reported and discussed in github under #134: Folder notes no longer open when clicking on the folder (Obsidian Desktop v1.5.4)
To simplify the life of not advanced users I’ve recently created a patched copy of the alx-folder-note and exposed it for easy installation with the well known BRAT plugin. The repository name to use in BRAT is https://github.com/SebastianMC/alx-folder-note.
All details and the background are clarified in my comment under #134 and in the updated readme of GitHub - SebastianMC/alx-folder-note
Hopefully this will make our life easier until the author applies relevant fixes onto the main repository.
As a workaround, I’ve found right-clicking on the folder and selecting “open folder note” does the job.
Thank you so much!
Tysm for creating this. Very useful!
Hello, FYI if you put [folderName](obsidian://search?query=path:folderName) inside a note, clicking on it will display the list of files in that folder into the left sidebar of Obsidian.
Also, if there is an “index” note inside the folder, you can link it with [[FolderName/index|index of FolderName]]
Personally I prefer this kind of “web style”, which let me put whatever I want into the index file. This is not automated, however. So your plugin might be interesting to automatically generate the index (or content) note. I will try it.
If you add this to your Folder Notes’ Note … it displays links to all the files in the folder :slight_smile:
filters:
  and:
    - file.inFolder(this.file.folder)
  - type: cards
    order:
      - file.name
it looks like this:
