Folder Move Option Removed from Right-Click Menu
In version v1.9.0, the core plugin “Files” (the left panel with file navigation) no longer allows moving folders via right-click. This option is now only available for notes through the “Move file to…” button.
Obsidian version: v1.9.0
Installer version: v1.8.9
Operating system: Darwin Kernel Version 24.4.0: Wed Mar 19 21:12:54 PDT 2025; root:xnu-11417.101.15~1/RELEASE_ARM64_T8103 24.4.0
Catalyst license: insider
Insider build toggle: on
Plugins installed: 9
Plugins enabled: 0
ok thanks
will be fixed in v1.9.2. No ETAs.
