“Focus on last note” not focusing on a different note
Hey everyone,
I just went to set my hot key for “Focus on last note” so I could “Ctrl + Tab” like I do on Firefox, but the command does not seem to do anything, either when a hotkey is assigned, or when the command is activated directly from the Command Palette. Am I misunderstanding what this command does?
Thanks,
Gus
To recreate, create a new vault, create one note Called Note 1. Create a second note called Note 2. With both notes open and Note 2 selected, open the Command Palette, type “focus on last note” and hit enter.
Yes, tried in a new sandbox vault.
I would expect to see the note switch from Note 2 back to Note 1, but instead, nothing happens.
No observed result.
Obsidian version: v1.11.4
Installer version: v1.9.14
Operating system: Windows 11 Pro Education 10.0.26100
Focus on last note is not for switching tabs. It’s for moving the focus from other parts of UI back to the editor.
Ah, I see. Thank you. Seems like I was looking for “Go to last tab”.
EDIT: Actually, it seems like this just takes me to the tab on the furtherest right. Is there a way to go to the last active tab/note?
