So I am trying to make a basic fixed TOC that follows the page as I scroll. (I know outliner exists, it’s horrible. I also don’t want to rely on plugins that break overtime.) Everything works fine… till I get about halfway down the page then it just disappears.
<div id="TOC" >
<ul>
<li><a class="internal-link" data-href="#Explore" href="#Explore" target="_blank" rel="noopener">Explore</a></li>
<li><a class="internal-link" data-href="#New" href="#New" target="_blank" rel="noopener">New</a></li>
</ul>
</div>
#TOC{
position: fixed;
top: 2rem;
right: 0;
display: inline-block;
float: right;
z-index: 10;
I’ve figured out that there is a scroll event handler that removes content as you scroll. But this also includes fixed content currently being viewed.
I’ve also included a Video
I don’t want to build my library using plugins that have to be maintained and break overtime. That’s a great way get stuck being dependent on specific platforms using specific plugins. I just want a basic TOC (Not the Outliner) that follows as I scroll.
I can’t create a side bar or any fixed position objects, scroll event handlers deletes/hides the side bar. Anyone have any ideas? Or anyone know how I can remove the scroll event handler from a specific div/element in Obsidian? I can’t read/write JS.
