All of the above also end up finding - [ ] some task. I’ve also looked into dataview but even the js API in the DataView plugin seems to operate on the page level rather than the block level.
Date: 1982-01-01
#Project/P01
## The Note Structures
### main tasks : CASE S1
- [[Note P]] main task GH
- [ ] task g
- [ ] task h
- [ ] task h1
- [ ] task h2
### main tasks : CASE S2
- [ ] [[Note P]] main task IJ
- [ ] task i
- [ ] task j
- [ ] task j1
- [ ] task j2
### some tasks : CASE S3
- some task MN
- [ ] task m
- [ ] task n
- [ ] task n1
- [ ] task n2 [[Note P]]
### some tasks : CASE S4
- [ ] some task RS
- [ ] task r
- [ ] task s
- [ ] task s1
- [ ] task s2 [[Note P]]
### other tasks: CASE S5
- other task UV
- [ ] task u
- [x] task v : Completed and not fullyCompleted
- [ ] task v1
- [ ] task v2
### other tasks: CASE S6
- [ ] other task XY
- [ ] task x
- [x] task y : Completed and not fullyCompleted
- [ ] task y1
- [ ] task y2
folder: 03_done_excluded_case
Summary_03
filename : dic_19820302
Date: 1982-03-02
#Project/P03
## input
### milestones
- 2004-03-01 add this feature_A #Test/d01 [[Note J]] , [[Note K]]
- 2004-03-02 add this feature_B #Test/d02 [[Note J]]
### main tasks : CASE S1(done)
- [x] task g
- [x] task h
- [x] task h1
- [x] task h2
filename : dic_19820307
Date: 1982-03-07
#Project/P03
## input
### main tasks : CASE S2(done)
- [x] [[Note P]] main task IJ
- [x] task i
- [x] task j
- [x] task j1
- [x] task j2
filename : dic_19820312
Date: 1982-03-12
#Project/P03
## input
### some tasks : CASE S3(done)
- some task MN
- [x] task m
- [x] task n
- [x] task n1
- [x] task n2 [[Note P]]
filename : dic_19820317
Date: 1982-03-17
#Project/P03
## input
### some tasks : CASE S4(done)
- [x] some task RS
- [x] task r
- [x] task s
- [x] task s1
- [x] task s2 [[Note P]]
filename : dic_19820322
Date: 1982-03-22
#Project/P03
## input
### other tasks : CASE S5(done)
- other task UV
- [x] task u
- [x] task v1
- [x] task v2
filename : dic_19820327
Date: 1982-03-27
#Project/P03
## input
### other tasks : CASE S6(done)
- [x] other task XY
- [x] task x
- [x] task y1
- [x] task y2
folder: 04_supported_case
Summary_04
filename : dic_19820402
Date: 1982-04-02
#Project/P04
## input
>CASE S1 =>
>case_FLST_LwithOL-T : A root list item contains an outlink like [[[Note P]] and a sub task item which is not fullyCompleted.
>FLST : Use file.lists
>L : an element of file.lists
>OL : L.outlinks
>FLST_L : A root list item L
>FLST_T : A root task item T
>-T : A sub task item T
- [[Note P]] links to a project
- [ ] do this task
- [ ] and that task
- [x] and that task01
- here’s a regular line
- [ ] one last task
- [ ] c3
- [ ] c4
- [ ] c5
- [ ] c6
- [x] one last task01
filename : dic_19820407
Date: 1982-04-07
#Project/P04
## input
>CASE S2=>
>case_FLST_TwithOL-T : A root task item which is not fullyCompleted contains an outlink like [[[Note P]] and a sub task item.
>OL : L.outlinks
- [ ] also remember to do this task for [[Note P]]
- some more text with no task
- [x] but a peer that is a task01
- [ ] but a peer that is a task
- [ ] and a child with another task
- [x] and a child with another task01
filename : dic_19820412
Date: 1982-04-12
#Project/P04
## input
>CASE S3 =>
>case_FLST_LwithoutOL-T-TwithOL : A root list item doesn't contain an outlink and the last subtask item which is not fullyCompleted contains an outlink like [[[Note P]].
>OL : L.outlinks
- last list of things to do remember to do this task
- [ ] the only task I wouldn’t want to return because it doesn’t link to my test file
- [ ] this is the actual last task [[Note P]]
filename : dic_19820417
Date: 1982-04-17
#Project/P04
## input
>CASE S4 =>
>case_FLST_TwithoutOL-T-TwithOL A root task item doesn't contain an outlink and the last subtask item which is not fullyCompleted contains an outlink like [[[Note P]].
>OL : L.outlinks
- [ ] last list of things to do remember to do this task
folder: 05_supported_not_fullyCompleted
Summary_05
filename : dic_19820522
Date: 1982-05-22
#Project/P05
## input
>CASE S5 =>
>case_FLST_LwithoutOL-TwithoutOL-TwithoutOL : A root list item which contains an uncompleted subtask item doesn't contain an outlink and any sub task item doesn't contain an outlink.
>OL : L.outlinks
- 1.==This should be shown==
- 1.1 This should be hidden
- [x] 1.2 This should be hidden
- [ ] 1.3 ==This should be shown==
- 1.3.1 This should be hidden
- [x] 1.3.2 Completed and not fullyCompleted ==This should be shown, as it contains uncompleted sub-tasks==
- 1.3.2.1 This should be hidden
- [ ] 1.3.2.2 ==This should be shown==
- [x] 1.3.2.3 This should be hidden
- [ ] 1.3.3 ==This should be shown==
- 1.4 ==This should be shown, as it contains uncompleted sub-tasks==
- 1.4.1 This should be hidden
- [ ] 1.4.2 ==This should be shown==
- [x] 1.4.3 This should be hidden
filename : dic_19820527
Date: 1982-05-27
#Project/P05
## input
>CASE S6 =>
>case_FLST_TwithoutOL-TwithoutOL-TwithoutOL : A root task item which is not fullyCompleted doesn't contain an outlink and any sub task item doesn't contain an outlink.
>OL : L.outlinks
- [ ] 1.==This should be shown==
folder: 08_excluded_case
Summary_08
filename : dic_19820802
Date: 1982-08-02
#Project/P08
## input
- [[My Test File]] links to a project
- [ ] do this task
- [ ] and that task
- [ ] one last task
- [ ] c3
- [ ] c4
- [ ] c5
- [ ] c6
filename : dic_19820807
Date: 1982-08-07
#Project/P08
## input
- [ ] also remember to do this task for [[My Test File]]
filename : dic_19820812
Date: 1982-08-12
#Project/P08
## input
- [ ] this is the actual last task [[My Test File]]
filename : dic_19820817
Date: 1982-08-17
#Project/P08
## input
DVJS10_use_fLists_hide_fullyCompleted_subTasks_and_display_uncompleted_tasks: For CASE S1 to S6
file.lists: a list item or a task item with L.outlinks or not
yes
1.To hide fullyCompleted sub-tasks 2.To show uncompleted sub-tasks under list items and completed (sub)-tasks 3.To show items that contain a specific outlink 4.To display the result by using dv.taskList [with the original structure]
1.The DVJS10 is based on the DVJS10 in the following topic. - Solutions: by Justdoitcc
2.Recursive Functions: 2.1 taskAny 2.2 hide_fullyCompleted_subTasks 2.3 designed by Developers: 2.3.1 jqhoogland@GiHub 2.3.2 wenlzhang@GiHub
Notes
Summary_notes
Q1: How to get the page information from the current note?
Original example
```dataviewjs
// M11. define pages: gather all relevant pages
// let pages = dv.current();
let pages = dv
.pages('"100_Project/01_dataviewjs/01_by_example/Q23_Mentions/Q23_test_data" and #Project')
.where((page) => dv.func.contains(page.file.name, "dic_"));
A1:
```dataviewjs
// let pages = dv
// .pages('"100_Project/01_dataviewjs/01_by_example/Q23_Mentions/Q23_test_data" and #Project')
// .where((page) => dv.func.contains(page.file.name, "dic_"));
Q2: How to get the filename of the current note?
Original example
```dataviewjs
// M09. define PARTIAL_FILENAME_OF_LINK:
// get the filename of the current note
// const PARTIAL_FILENAME_OF_LINK = dv.current().file.name;
const PARTIAL_FILENAME_OF_LINK = "Note P";
A2:
```dataviewjs
// const PARTIAL_FILENAME_OF_LINK = "Note P";
code DVJS10_use_fLists_hide_fullyCompleted_subTasks_and_display_uncompleted_tasks: For CASE S1 to S6
Summary_code
title: DVJS10_use_fLists_hide_fullyCompleted_subTasks_and_display_uncompleted_tasks => 1.To hide fullyCompleted sub-tasks 2.To show uncompleted sub-tasks under list items and completed (sub)-tasks 3.To show items that contain a specific outlink 4.To display the result by using `dv.taskList` [with the original structure]
collapse: close
icon:
color:
```dataviewjs
// M01. define b_SHOW_ANY_LIST_ITEMS:
// false: To hide any list items (default)
// true : To show any list items
// Q: What do list items mean?
// A1: list items with no children
// A2: list items with sublist items that have no children
// A3: list items with children that contain fullyCompleted tasks in any generation
// A4: list items with sublist items whose children contain fullyCompleted tasks in any generation
// let b_SHOW_ANY_LIST_ITEMS = false;
let pages = dv
// M21. define Recursive Function:To expand search to children
const taskAny = function taskAny(t, f) {
if (f(t)) {
return true;
for (let sub of t.children) {
if (taskAny(sub, f)) {
return true;
return false;
// M25. define Recursive Function:To gather un-fullyCompleted children
// (1.To hide a fullyCompleted subtask item 2.Not to hide a root item)
// FLATTEN_CASE_10A:To gather an un-fullyCompleted task item that
// doesn't contain an outlink
// FLATTEN_CASE_10B:To gather an un-fullyCompleted task item that
// contains a specific outlink
// (CASE S3 or S4: For example
// 1.To gather the last un-fullyCompleted subtask
// item which contains an outlink like [[[Note P]]
// in the [[dic_19820412]] or [[dic_19820417]]
// 2.To exclude the last un-fullyCompleted subtask
// item which contains an outlink like [[[My Test File]]
// in the [[dic_19820812]] and [[dic_19820817]]
// dv.span(hide_fullyCompleted_subTasks(root_tasks_or_lists.text));
const hide_fullyCompleted_subTasks = (t) => ({
...t,
children: t.children
.filter((st) =>
taskAny(
st,
(st) =>
(st.task &&
!st.fullyCompleted &&
st.outlinks.length === 0) ||
(st.task &&
dv.func.contains(
st.outlinks.map((hLink) =>
hLink.path.replace("^(.*/)(.+)(.md)$", "$2")
.map(hide_fullyCompleted_subTasks),
// M31. define root_tasks_or_lists : gather a root item
// WHERE_CASE_11 :To gather a root list item or a root task item
// (comments)WHERE_CASE_12A:To gather a root task item which is not fullyCompleted
// (comments)WHERE_CASE_12B:To gather a root list item which contains a subtask
// (comments) item that is not fullyCompleted
// (comments) (CASE S1 or S3 or S5: To gather
// (comments) [[dic_19820402]] or [[dic_19820412]] or [[dic_19820522]])
// WHERE_CASE_13A:To gather a root task item which is not fullyCompleted and
// (CASE S4 or S6:To gather [[dic_19820417]] or [[dic_19820527]])
// WHERE_CASE_13B:To gather a root task item which is not fullyCompleted and
// (CASE S2:To gather [[dic_19820407]] and exclude [[dic_19820807]])
// WHERE_CASE_13C:To gather a root list item which contains an un-fullyCompleted
// subtask item and doesn't contain a specific outlink
// (CASE S3 or S5:To gather [[dic_19820412]] or [[dic_19820522]])
// WHERE_CASE_13D:To gather a root list item which contains an un-fullyCompleted
// subtask item and contains a specific outlink
// (CASE S1:To gather [[dic_19820402]] and exclude [[dic_19820802]])
let root_tasks_or_lists = pages.file.lists
.where((L) => !L.parent)
// .where(
// (L) =>
// (L.task && !L.fullyCompleted) ||
// (!L.task &&
// L.children.length > 0 &&
// L.children.filter((c) => c.task && !c.fullyCompleted))
.where(
(L) =>
(L.task && !L.fullyCompleted && L.outlinks.length === 0) ||
(L.task &&
dv.func.contains(
L.outlinks.map((hLink) =>
(!L.task &&
L.children.filter((c) => c.task && !c.fullyCompleted) &&
(!L.task &&
dv.func.contains(
// M33. Hide completed Subtasks:
root_tasks_or_lists.values = root_tasks_or_lists.values.map(
// M81. deal with root_tasks_or_lists:
// To groupBy t.path
// To sort in ascending order
// t.path : "100_Project/02_dataview/Q12_Tasks/Q12_test_data02/08/dic_20110801.md"
// group.key: "100_Project/02_dataview/Q12_Tasks/Q12_test_data02/08/dic_20110801.md"
root_tasks_or_lists = root_tasks_or_lists
.groupBy((t) => t.path)
.sort((group) => group.key, "asc");
// M83. output root_tasks_or_lists:
for (let group of root_tasks_or_lists) {
// M83.FR13 define s_display_name:
let s_file_name = dv.page(group.key).file.name;
let s_display_name = s_file_name + ": ";
// M83.FR15 define s_link: \[[alphabet#a|pqr]\] //=>pqr
// let s_link = "[[" + group.key + "#" + Heading + "|" + s_display_name + "]]";//=>pqr
let s_link = "[[" + group.key + "|" + s_display_name + "]]";
// M83.FR21 output s_link: \[[08/dic_20110801.md|dic_20110301: 7 uncompleted]\]
dv.header(3, s_link);
// M83.FR31 output group.rows:
dv.taskList(group.rows, false);
Wow @justdoitcc, this is a Herculean effort. Thank you for sharing. Looking through the git history, there have been tremendous improvements in the readability of the dataview docs since I posted this. (–or I just missed it : P )
Anyways, I’m sharing the below Javascript snippet for those who come across this to help with the above issue. Some portions are directly inspired from your work as well, @justdoitcc, so thank you!
Note: throw backticks and the dataviewjs label on the below code
/* Intelligently collect tasks using dataview
This dataview collects all tasks from pages specified by a query. It renders
all tasks that have any un-completed subtasks.
Author: Adithya Balaji (https://www.adithyabalaji.com/about)
// The base tag to search for
const LINK_TAG = '[[anki inbox]]';
// The base filter query to use to collect pages. Use an empty string to collect
// all pages. See the linked docs to learn what are valid querys
// https://blacksmithgu.github.io/obsidian-dataview/api/code-reference/#dvpagessource
const PAGE_FILTER_QUERY = LINK_TAG;
const GROUP_HEADER_LEVEL = 3
* [cleanTasks Remove non tasks (bare list items) and completed tasks]
function cleanTasks(taskRoot) {
// all cases where we want to filter out the task immediately
if (!taskRoot.task || taskRoot.fullyCompleted) {
return false
// the case where it's a task that may contain children,
} else if (taskRoot.children) {
taskRoot.children = taskRoot.children.filter(cleanTasks);
return !!taskRoot.children;
// the case where it's a singular task remaining
} else {
return taskRoot.completed
// Filter the initial search space of pages to only pages that even include the `LINK_TAG`
let pages = dv.pages(PAGE_FILTER_QUERY);
// Collect the list of root tasks that contain the specified link tag
let rootLists = pages.file.lists.where(listItem => listItem.text.includes(LINK_TAG));
let rootTasks = (
rootLists
// Collect and flatten the list of tasks underneath root list items
.flatMap(listItem => listItem.children)
// Only collect tasks that are not fully completed and are actually tasks (includes sub tasks)
.filter(cleanTasks)
// Group the list of tasks by the page that they originate from
.groupBy((taskItem) => taskItem.path)
// Sort the page headers in ascending order (A-Z)
for (let group of rootTasks) {
// Create a header backlink with a display alias for the group of tasks
let fileName = dv.page(group.key).file.name;
let displayName = fileName + ": ";
let displayLink = "[[" + group.key + "|" + displayName + "]]";
dv.header(GROUP_HEADER_LEVEL, displayLink);
